smpa01
1 year agoCommunity Champion
Converting Fabric dataframe to spark dataframe
How can I convert a sempy.fabric.fabricdataframe to spark df?
The following does not work
dataset = (fabric
.evaluate_dax(workspace= server,
dataset=db,
dax_string=query_string)
).to_pandas()
AttributeError: 'FabricDataFrame' object has no attribute 'to_pandas()'
dataset = (fabric .evaluate_dax(workspace= server, dataset=db, dax_string=query_string) ) spark_df = spark.createDataFrame(dataset)This works for me.
I think you can treat the Fabric dataframe as a Pandas dataframe, and convert it to a Spark dataframe the same way you would convert a Pandas dataframe to a Spark dataframe.
The FabricDataFrame class:- Supports all pandas operations.
- Subclasses the pandas DataFrame and adds metadata, such as semantic information and lineage.
- frithjof_vCommunity Champion
- smpa01Community Champion
Liked the 1-liner; took a longer route which I can happily discard
# data_as_dict = dataset.to_dict() # columns = dataset.columns # flattened_rows = [Row(**{col: data_as_dict[col][i] for col in columns}) for i in range(len(data_as_dict[columns[0]]))]
