Wilbike
Return Max Number result by Project, and combine max figures when Payment Type is the same
Hi Everyone,
I am trying to create a measure that is able to return the max Payment Value for a Project (1,2 or 3), and when the payment type is the same for the project, I'd like this combined value to be included when determining the maximum payment value for a project.
For example:
Project 2 has two Y payment types which have a combined value 110. I'd like this value to be produced from the MAX measure as the maximum Payment Value for this Project
The previous measure I have tried is:
=SUMX(VALUES(PaymentTable[Project]),CALCULATE(MAX(PaymentTable[Payment Value])))
But this will only return the single maximum figure for payment value, and not the combined value if the Payment Type is the same for a given project.
If this can be done without a measure then I'd be interested in hearing this to!
Thanks in advance!
Here's the same measure as @johnt75's but without the unnecessary fluff:
Max Value =
MAXX(
    DISTINCT( 'Table'[Payment type] )
    CALCULATE( SUM( 'Table'[Value] ) )
and might be faster as it does not materialize results as the measure above does because of ADDCOLUMNS.
Wilbike
Thanks for posting @johnt75 .
@daXtreme that solution worked! Thank you very much!
johnt75
You could create a measure like
Max Value =
VAR SummaryTable =
    ADDCOLUMNS (
        SUMMARIZE ( 'Table', 'Table'[Payment type] ),
        "@val", CALCULATE ( SUM ( 'Table'[Value] ) )
    MAXX ( SummaryTable, [@val] )
Max Value =
MAXX(
