Problem with DAX calculating a value using filters from two tables
Hi JayCee
If the return result is blank then the Selected Club do not exist in the Games table (as opponent) or otherise you need to double check the data taype and quality of both columns.
As side note I would say that 2nd filter "dimClubs[category] = 1" probably shall not be effective as both tables are dim tables and most propably there is no direct relationship between the two tables?
- JayCee3 years agoNew Member
Could it be, Clubs filter Games, but Games (opponent_id) can't filter back to Clubs (club_id)?
The related column is club_id in both, because this dataset I was given has 'two games' for every actual game, one hosting 'Home', the other hosting 'Away'.
I think I should insert kind of a "filter" inside the function, comparing 'opponent_id' with 'club_id' and 'category' = 1... or something like that.
My knowledge of DAX is very limited and I don't know how to even write long sentences in the correct order.
