Register now!To celebrate FabCon Vienna, we are offering 50% off select exams. Ends October 3rd. Request your discount now.
i try to group New column in top3 with A , B , C and Other
but i cant i dont understand why, can anyone plese send me super sample files .. T_T thank you
Hi @GhostTIT ,
Your DAX is available, but it's for use inside a measure not column:
The article describes the difference between column and measure, you could refer to: The differences between new measure and new column in Power BI - The Data School Down Under
New columns are static and calculated based on existing data, while measures are dynamic and based on aggregated data.
What's more, you could create the new column or measure under this tab:
And in case you want to create a column to achieve the output, please follow the method below:
ProductTop3andOthers_column =
VAR _a = financials[Sale_column]
VAR _b = RANKX(financials, [Sale_column], , DESC, Dense)
IF(_b <= 3 , financials[Product] , "Other")
Xianda Tang
Hi @GhostTIT ,
Xianda Tang
this is my sample files
Again , i want to create New colum with this code
