I try to do cumulative on a measure name #Exp this is my problem.
I have a table name Expenses which has no relationship with any table.
This is my measure:
#Exp =
SUM( 'Expenses' [Expenses]),
FILTER(
'Expenses' ,
'Expenses' [Month] = SELECTEDVALUE('Date' [Month])
'Expenses ' [Poo]] = SELECTEDVALUE (tbMaster_UnitGroup[New_Map]) ||
ISFILTERED (tbMaster_UnitGroup[New_Map]) = FALSE()
'Expenses' [EngagementProfitCtrName] = SELECTEDVALUE (Alocation Summary [UnitG]) ||
ISFILTERED (Alocation Summary[UnitG]) = FALSE()
'Expenses [FY] = SELECTEDVALUE ('Date "[FY]) ||
ISFILTERED(Date' [FY]) = FALSE ()
'Expenses' [month] = SELECTEDVALUE ('Date' [Month]))))
I try many way but this measure is the only way that returns my data correctly.
The problem I face is that I tried to get cumulative of #Exp and I did every way to cumulative by this measure, but it is still not cumulative.
I have tired something like
Cul = calculate( #Exp , Filter('expenses',expenses[Date] <=max( expenses[Date])) It is not working.
Hi @Moji_mook ,
We can create a measure.
Cul_exp = SUMX(FILTER(ALLSELECTED('date'),YEAR('date'[Date])= YEAR(MAX('date'[Date]))&&MONTH('date'[Date])<=MONTH(MAX('date'[Date]))),[#Exp])
If the above one can't help you get the desired result, please provide some sample data in your tables (exclude sensitive data) with Text format and your expected result with backend logic and special examples. It is better if you can share a simplified pbix file. Thank you.
Neeko Tang
Hi @Moji_mook ,
Neeko Tang
Hi @Moji_mook
Cummulative measure should be created using Time intelligence functions depending of your requirements
Check link https://learn.microsoft.com/en-us/dax/time-intelligence-functions-dax
Thanks you for the solution. Can you suggest me what time intelligence should I use for cumulative my measure. I have no Idea how to combine my measure with them
Hi @Moji_mook **bleep**.values should not be the issue.
Please share your table inputs and expected output.
Usually, YTD is fair cumulative measure.
My table look like this:
Month | #Exp | Cul_Exp (expected results)
Jan 100 100
Feb 100 200
Mar 100 300
Apr 100 400
May 100 500
Jun 100 600
Jul 100 700
Aug 100 800
Sep 100 900
Oct 100 1000
Nov 100 1100
Dec 100 1200
[#Exp] display correctly but Cul_Exp (expected results) not working.
Month is from date table. [Exp] Is the measure I provided below. #Exp sum from [Expenses] in table expenses which has no relationship with any table. It cannot has relationship with any table because every time it has relationship with table it returns incorrect value.
#Exp =
FILTER(
'Expenses' ,
Hi @Moji_mook
Create date table and conect it with your fact table. After that try YTD measure
Measure YTD=TOTALYTD(SUM( 'Expenses' [Expenses]),DateTime[DateKey] )
Link for details
https://learn.microsoft.com/en-us/dax/totalytd-function-dax?WT.mc_id=DP-MVP-4025372
| 9 | |
| 3 | |
| 3 |
| 13 | |
| 9 | |
| 9 | |
| 8 | |
| 7 |
