Power BI DAX help
- 3 years ago
Thanks for clarifying.
try this.
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("Vc89DsIwDAXgu2SmUqHiAMYJ0KqmITZTVVWdECv3H/iTqJ+n90mOnjOOwZb73D2eS5g2YyDWals3zX73o2i62Dd2baHqn2aynnRl5CGvrOrPrCQu6eqpAJAlEufIAL+afBY17EiZRdCqBd5kUBmcTu9v+67WZ1/Ts3kdo5MMALxPlG4GC3pQBjMyoc5hml4=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]),
#"Promoted Headers" = Table.PromoteHeaders(Source, [PromoteAllScalars=true]),
#"Changed Type1" = Table.TransformColumnTypes(#"Promoted Headers",{{"Tag_Jira", type text}}),
#"Added Custom" = Table.AddColumn(#"Changed Type1", "Custom", each if Text.StartsWith([Tag_Jira],"JIRA-") and Text.Length([Tag_Jira])=10 then "yes" else "no")
#"Added Custom" - 3 years ago
if you want a calculated column in the data view,
try =if ( LEFT('Table (3)'[Tag_Jira],5)= "JIRA-" && LEN('Table (3)'[Tag_Jira])=10, "yes","no")
Hi zenbex,
You can create a calculated column in power query.
paste the code below in a blank query for my solution:
#"Added Custom" = Table.AddColumn(#"Changed Type1", "Custom", each if Text.Contains([Tag_Jira],"JIRA") then "Yes" else "No")
#"Added Custom"
Please let me know if this resolves the question.
Appreciate a thumbs up if this is helpful.
Thank you for fast reply. but my quetion was a value the begins with "JIRA-" and five character only will be yes other wise it will be NO
- adudani3 years ago
Memorable Member
try this.
#"Added Custom"- zenbex3 years agoNew Member
Thank you so much this one is correct. is there a way i can use from the existing table columns ? like i have table[DimJira] where Tag_Jira column Available
thanks
