Nested (3 levels) TOPN using Power BI DAX not working for categories but working for other
- 2 years ago
Hi TFRec
lbendlin already provided a very good approach, but still, if you seeking another way of doing that you can check this video this is not exact but with some modification this might help you to attain solution: https://youtu.be/cs2AwJljBrQ?si=yQR7T5WZZMfTaSDh
Did I answer your question? Mark my post as a solution! Appreciate your Kudos!!
Check for more intersing solution here: www.youtube.com/@Howtosolveprobem
Regards
Hi TFRec
Regards
Hello qqqqqwwwweeerrr ,
Thank you so much for this. I just had to modify it a little bit and it works perfectly. I was really overcomplicating it with my use of nested TOPNs with KEEPFILTERS.
Top 3 multiple test =
VAR RankCode = RANKX(
ALLSELECTED(Table[Product_code]),[Sum Euros All Time],,DESC,Dense
VAR RankOrigin =
RANKX(
ALLSELECTED(Table[Origin_COuntry]),[Sum Euros All Time],,DESC,Dense
VAR RankDestination =
RANKX(
ALLSELECTED(Table[Destination_Country]),[Sum Euros All Time],,DESC,Dense
VAR RankAll =
SWITCH(
TRUE,
ISINSCOPE(Table[Destination_Country]),RankDestination,
ISINSCOPE(Table[Origin_Country]),RankOrigin,
ISINSCOPE(Table[Product_code]),RankCode
IF(
RankAll <= 3, [SumEuros],BLANK()
