2 years agoNot applicable
Need urgent help on convertion from Rows values to Column values in Power Bi
Hi All, Please help on the below excel data file and screenshot to convert from Rows values to Column values in Power Bi. I have tried so many triles, but unable to reach to solution. Please ...
- Anonymous2 years ago
Hi Anonymous ,
In PBI Desktop, click "transform data" to enter the power query editor, then click "Advanced Editor" to copy and paste the following code. You can view the steps in the Steps column on the right, and you can modify the data source by clicking the gear next to "Source".
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("hdRBCoQwDIXhq4jrcXhJmyaeRbz/NYbpiOLYJLsHP/0WpXTbZhOqymUCLYSF8Z1vgGXSeX/dOtak2623R9ekt6RL0uuty6OXpHPS6dbrf6d+nv1OSceoFxTYsYG1ofSt1nQVHBtElX9bxVD1vE+y7olMeHQ5epQU8KsHVx+uIVwTuPhwCeGSwOzDHMKcwOTDFMIUw/2xkY7gK43gs3ow+TCFMCUwfBghjBju/9IYvtLwjtcENh+2ELYEVh/WEFYfnvf9Aw==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"POLICY_7DIGIT BUYING_YEARS_MONTHS INTEREST_RATE_CALCULATION INCREASED_LIVING_BENEFIT" = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"POLICY_7DIGIT BUYING_YEARS_MONTHS INTEREST_RATE_CALCULATION INCREASED_LIVING_BENEFIT", type text}}), #"Demoted Headers" = Table.DemoteHeaders(#"Changed Type"), #"Changed Type1" = Table.TransformColumnTypes(#"Demoted Headers",{{"Column1", type text}}), #"Split Column by Delimiter" = Table.SplitColumn(#"Changed Type1", "Column1", Splitter.SplitTextByDelimiter(" ", QuoteStyle.Csv), {"Column1.1", "Column1.2", "Column1.3", "Column1.4"}), #"Changed Type2" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Column1.1", type text}, {"Column1.2", type text}, {"Column1.3", type text}, {"Column1.4", type text}}), #"Promoted Headers" = Table.PromoteHeaders(#"Changed Type2", [PromoteAllScalars=true]), #"Changed Type3" = Table.TransformColumnTypes(#"Promoted Headers",{{"POLICY_7DIGIT", Int64.Type}, {"BUYING_YEARS_MONTHS", type date}, {"INTEREST_RATE_CALCULATION", type number}, {"INCREASED_LIVING_BENEFIT", Int64.Type}}), #"Grouped Rows" = Table.Group(#"Changed Type3", {"POLICY_7DIGIT"}, {{"Data", each Table.FromColumns(List.Transform(List.Combine(Table.ToRows(Table.SelectColumns(_,{"BUYING_YEARS_MONTHS","INTEREST_RATE_CALCULATION","INCREASED_LIVING_BENEFIT"}))),each {_}))}}), #"Expanded Data" = Table.ExpandTableColumn(#"Grouped Rows", "Data", {"Column1", "Column2", "Column3", "Column4", "Column5", "Column6", "Column7", "Column8", "Column9", "Column10", "Column11", "Column12", "Column13", "Column14", "Column15", "Column16", "Column17", "Column18", "Column19", "Column20", "Column21", "Column22", "Column23", "Column24", "Column25", "Column26", "Column27", "Column28", "Column29", "Column30", "Column31", "Column32", "Column33", "Column34", "Column35", "Column36", "Column37", "Column38", "Column39", "Column40", "Column41", "Column42", "Column43", "Column44", "Column45", "Column46", "Column47", "Column48", "Column49", "Column50", "Column51", "Column52", "Column53", "Column54", "Column55", "Column56", "Column57", "Column58", "Column59", "Column60", "Column61", "Column62", "Column63", "Column64", "Column65", "Column66", "Column67", "Column68", "Column69", "Column70", "Column71", "Column72", "Column73", "Column74", "Column75", "Column76", "Column77", "Column78", "Column79", "Column80", "Column81", "Column82", "Column83", "Column84", "Column85", "Column86", "Column87", "Column88", "Column89", "Column90", "Column91", "Column92", "Column93", "Column94", "Column95", "Column96", "Column97", "Column98", "Column99", "Column100", "Column101", "Column102", "Column103", "Column104", "Column105"}, {"Data.Column1", "Data.Column2", "Data.Column3", "Data.Column4", "Data.Column5", "Data.Column6", "Data.Column7", "Data.Column8", "Data.Column9", "Data.Column10", "Data.Column11", "Data.Column12", "Data.Column13", "Data.Column14", "Data.Column15", "Data.Column16", "Data.Column17", "Data.Column18", "Data.Column19", "Data.Column20", "Data.Column21", "Data.Column22", "Data.Column23", "Data.Column24", "Data.Column25", "Data.Column26", "Data.Column27", "Data.Column28", "Data.Column29", "Data.Column30", "Data.Column31", "Data.Column32", "Data.Column33", "Data.Column34", "Data.Column35", "Data.Column36", "Data.Column37", "Data.Column38", "Data.Column39", "Data.Column40", "Data.Column41", "Data.Column42", "Data.Column43", "Data.Column44", "Data.Column45", "Data.Column46", "Data.Column47", "Data.Column48", "Data.Column49", "Data.Column50", "Data.Column51", "Data.Column52", "Data.Column53", "Data.Column54", "Data.Column55", "Data.Column56", "Data.Column57", "Data.Column58", "Data.Column59", "Data.Column60", "Data.Column61", "Data.Column62", "Data.Column63", "Data.Column64", "Data.Column65", "Data.Column66", "Data.Column67", "Data.Column68", "Data.Column69", "Data.Column70", "Data.Column71", "Data.Column72", "Data.Column73", "Data.Column74", "Data.Column75", "Data.Column76", "Data.Column77", "Data.Column78", "Data.Column79", "Data.Column80", "Data.Column81", "Data.Column82", "Data.Column83", "Data.Column84", "Data.Column85", "Data.Column86", "Data.Column87", "Data.Column88", "Data.Column89", "Data.Column90", "Data.Column91", "Data.Column92", "Data.Column93", "Data.Column94", "Data.Column95", "Data.Column96", "Data.Column97", "Data.Column98", "Data.Column99", "Data.Column100", "Data.Column101", "Data.Column102", "Data.Column103", "Data.Column104", "Data.Column105"}) in #"Expanded Data"Best Regards,
Neeko Tang
Hi Anonymous
Is it possible to create a DAX ? Please help
Hi Anonymous ,
As far as I know, DAX can't achieve the results you need.Power Query is good for data cleansing.
Neeko Tang
