emembreno81
Need help with converting and IF(OR(ISNUMBER formula into DAX
Hello!
I am converting a formula from Excel into Power BI.  The Excel formla is the following:
=IF(OR(ISNUMBER(SEARCH({"tbd"},Y104)),Y104="",),"INCOMPLETE","COMPLETE")
someone did help me out and provided a formula that does seem to be the start of what I'm trying to execute, but it looks like it might be looking for instances where "tbd" is the ONLY value in the cell whereas I need the formula to find instances where "tbd" shows up in the data located in each cell.  The formula provided is:
Invalid Color =
var _value =
if('rep v_asrt_mo_rep'[Color Short Description] = "" || 'rep v_asrt_mo_rep'[Color Short Description] = "tbd" , "INCOMPLETE","COMPLETE")
return
_value
I think this formula is missing the search functionality - or is there a way to rewrite this formula to also include a CONTAINS function?
I would appreciate any help with this!
@emembreno81 , Try like
if('rep v_asrt_mo_rep'[Color Short Description] = "" || search("tbd",'rep v_asrt_mo_rep'[Color Short Description],,0)>0 , "INCOMPLETE","COMPLETE")
SEARCH and FIND: https://www.youtube.com/watch?v=mZt0HJw4gjQ&list=PLPaNVDMhUXGaaqV92SBD5X2hk3TMNlHhb&index=45
CONTAINSSTRING and CONTAINSSTRINGEXACT: https://www.youtube.com/watch?v=XbgLGDvWdWQ&list=PLPaNVDMhUXGaaqV92SBD5X2hk3TMNlHhb&index=44
Thank you so much!  This did the trick!
