Need help to calculate aggregate column based on mesure value
I'm new in Power Bi and DAX world and come from Tableau.
I would like to create a column with DAX (not measure) wich give me the amount of sales for each customer/brand/year. I would like to create segmentation from this column, that's why I don't want a measure.
Here's my test model :
What i want is this (amount_customer_year) :
and if I remove "année", "product" and "brand" column, i keep the same granularity.
amount_customer_year_brand is a new attribut for my customers.
I solved this problem with a single table model
with the following formula :
amount_customer_year_brand = CALCULATE(
                sum(Sales_full[amount]),
                ALLEXCEPT(Sales_full,Sales_full[customer_code],Sales_full[Date].[Année],Sales_full[product_brand])
 it works like a charm, but i can't make it works with my "3 tables model".
Can you help me making this formula works on my "3 tables schémas".
thank you in advance
Here's my test Data
Customer :
customer_codecustomer_label
1Customer_1
2Customer_2
Product
product_codeproduct_labelproduct_brand
1product_1Brand_1
2product_2Brand_1
3product_3Brand_2
4product_4Brand_2
Sales
Sales_idcustomer_codeproduct_codedateamount
11101/01/202010
21101/05/202010
31201/06/202030
41301/07/2020100
51401/08/20201000
61401/09/20201000
71301/07/2021100
81401/08/20211000
91401/09/20211000
102101/01/202020
112201/05/202060
122201/06/202060
132201/07/2021120
Sales_full
Sales_idcustomer_codeproduct_codeDateamountCustomer_labelproduct_labelproduct_brand
11101/01/202010Customer_1product_1Brand_1
21101/05/202010Customer_1product_1Brand_1
31201/06/202030Customer_1product_2Brand_1
41301/07/2020100Customer_1product_3Brand_2
51401/08/20201000Customer_1product_4Brand_2
61401/09/20201000Customer_1product_4Brand_2
71301/07/2021100Customer_1product_3Brand_2
81401/08/20211000Customer_1product_4Brand_2
91401/09/20211000Customer_1product_4Brand_2
102101/01/202020Customer_2product_1Brand_1
112201/05/202060Customer_2product_2Brand_1
122201/06/202060Customer_2product_2Brand_1
132201/07/2021120Customer_2product_2Brand_1
Thank you again for reading this far
jameszhang0805
Resolver IV
Resolver IV
Is this the expected result?
Thank you for your anwser, but unfortunatly, no, the customer_1 should have 3 values even if i don't display brand_product or "Année"(year).
in fact there is a mistake in my original post, there should have 3 values not 2, so my formula doesn't work for my one table model :'(
HotChilli
Something's not adding up (really!)
I've built the pbix but I don't see the same results as you show.
Is the picture with customer_label and the amount_customer_year_brand missing a column? Because powerbi would merge those rows otherwise.
I also don't get the results from the first visual with the amount_customer_year_brand column
Perhaps you could link your pbix (you need to use a 3rd party site) and I'll take a look
Thank you for your reply.
Here my two pbix files, hope this will work.
https://1drv.ms/u/s!Ar16OoDci-UGhNhXGDJ6Uk5_E5NauQ?e=bBmQGE
Sry for delay
