sushma1412_Ind's avatar
sushma1412_Ind
4 years ago
Need help on filtering multiple values of same columns using And
This is my data .
Here i want  to find out count of employees who has done both Power BI and Azure.
As per data only Empid =1 is the only employee who has done both certifications and count should be one and that count i want to use in other calculations.
  • Here is the solution .create a measure as below will give results
    ABC =
    var aTT = SUMMARIZE(
    FILTER(ALL(Emp),Emp[Certification]="Power BI"),Emp[Empid],Emp[Certification])
    var bTT = SUMMARIZE(
    FILTER(ALL(Emp),Emp[Certification]="Azure"),Emp[Empid],Emp[Certification])
    return
    COUNTROWS(NATURALINNERJOIN(SELECTCOLUMNS(aTT,"EmployeeID",Emp[Empid]),SELECTCOLUMNS(bTT,"EmployeeID",Emp[Empid])))
  • sushma1412_Ind
    You can create a the following measure
    Count of Emp =
        DISTINCTCOUNT ( tablename(empid),
        tablename(certification) IN {"Power BI" , "Azure"} )
    • sushma1412_Ind's avatar
      sushma1412_Ind
      Fowmy - This will work as OR condition and it will give the count of employees who has done power bi or Azure and we will get count as 2 but i want count as 1 who has done both Powerbi and Azure
      • Fowmy's avatar
        Fowmy
        sushma1412_Ind
        The formula I shared should give you one as the result as I have used DISTINCTCOUNT.
        If you use AND then you wont any results as a single row cannot contain both so please test it and reply
    ABC =
    return
