Need help od DAX Minimum and maximum function
I want to develop Matrix for person login per day as following but not able to create min and max like below
Note - Date is in column, there is another calulcate column # of login.
Can someone tell me what DAX formula use to create column for min and max.
| City | User | 1/1 | 1/2 | 1/3 | 1/4 | 1/5 | 1/6 | min | max |
| Aatlanta | 15 | 12 | 3 | 15 | 7 | 5 | 9 | 3 | 15 |
| Chicagot | 12 | 0 | 1 | 11 | 7 | 5 | 9 | 0 | 11 |
- Anonymous2 years ago
Hi Anonymous ,
Here some steps that I want to share, you can check them if they suitable for your requirement.
Here is my test data:
Create two measures
MaxLogins = CALCULATE( MAX('Table'[Value]), FILTER( 'Table', 'Table'[Column] <> "User" ) )MinLogins = CALCULATE( MIN('Table'[Value]), ALLEXCEPT('Table', 'Table'[City]) )Final output
However, this is based on the data I created. In fact matrix is based on the original table adding two columns behind it is not generating it. If this method doesn't work for your file, please provide your pbix file including your table to table relationships, tables, and hide sensitive information ahead of time. This way we can help you faster.
Best regards,
Albert He
- bhanu_gautamSuper User
Anonymous , You can try below DAX
for minimum
Min_Login = MINX(VALUES('YourTableName'[User]), CALCULATE(MIN('YourTableName'[# of login])))
For maximum
Max_Login = MAXX(VALUES('YourTableName'[User]), CALCULATE(MAX('YourTableName'[# of login])))
Please accept as solution and give kudos if it helps
- AnonymousNot applicable
Hi Anonymous ,
Create two measures
Best regards,
Albert He
