Anonymous's avatar
2 years ago
Need help od DAX Minimum and maximum function
I want to develop Matrix for person login per day as following but not able to create min and max like below Note - Date is in column, there is another calulcate column # of login.   Can someone t...
    2 years ago
    Hi Anonymous ,
    Here some steps that I want to share, you can check them if they suitable for your requirement.
    Here is my test data:
    Create two measures
    MaxLogins =
    CALCULATE(
        MAX('Table'[Value]),
        FILTER(
            'Table',
            'Table'[Column] <> "User"
    MinLogins =
    CALCULATE(
        MIN('Table'[Value]),
        ALLEXCEPT('Table', 'Table'[City])
    Final output
    However, this is based on the data I created. In fact matrix is based on the original table adding two columns behind it is not generating it. If this method doesn't work for your file, please provide your pbix file including your table to table relationships, tables, and hide sensitive information ahead of time. This way we can help you faster.
    Best regards,
    Albert He
