kc_1116
Need help in using Field Parameter in Top N filter and Conditional Formatting
I have a report that has conditional formatting and Top N filter on a static measure named IRR and it works perfectly. However, I want to change the measure to dynamic and allow user to select among a few other measures like DPI, RVPI and TVPI. I have created a Field Parameter and add all measures to it. It works for the bar chart at the bottom. However, I couldn't get the conditional formating to work. Also, the Top N filter based on that field parameter is not working properly. Can you advise how can I fix them, please? Thanks in advance.
URL of my Power BI Report: https://github.com/chris-kc-cheng/ftk-powerbi/blob/main/Private%20Markets.pbix
DataNinja777
Hi @kc_1116 ,
In order to create conditional formatting for your bar chart, you can create a measure like below:
Selected Metric Value =
VAR Selection = SELECTEDVALUE('Metric Selector'[Metric Selector Order])
SWITCH( Selection,
    0, [M_IRR],
    1, [M_DPI],
    2, [M_RVPI],
    3, [M_TVPI],
    [M_IRR]
Then you can apply conditional color formatting in the bar:
Set the conditional formatting like below:
The resultant output is as shown blow:
I have attached an example pbix file for your reference:
Best regards,
Punithurs
Refer to this short video for Top N filtering logic walkthrough.
https://www.youtube.com/watch?v=gnCHB5jBQbA&t=15s
Punith
DataNinja777
Hi @kc_1116 ,
SWITCH( Selection,
    0, [M_IRR],
    1, [M_DPI],
    2, [M_RVPI],
    3, [M_TVPI],
    [M_IRR]
Best regards,
Amazing. Your DAX magically solved both the conditional formatting and Top N filter problems. Thanks so much for your help.
@kc_1116 , I think the main idea would be to know the selected measure and have conditional formatting based on that . Check if the below method can help
Field Parameters- Conditional Formatting
: https://amitchandak.medium.com/field-parameters-conditional-formatting-517aacc23fdf
Switch TOPN with Field Parameters: https://amitchandak.medium.com/switch-topn-with-field-parameters-299a0ae3725f
