Learn moreNext up in the FabCon + SQLCon recap series: The roadmap for Microsoft SQL and Maximizing Developer experiences in Fabric. All sessions are available on-demand after the live show. Register now
Can anyone of you help me to figure out why my subtotals are not populating here please? If i add the all selected to the product level still it end up giving me the wrong result in matrix visual. Please let me know if you need any more information. Thanks!
In matrix I have product level on top and the site names are at the sublevel in matrix rows.
@Anonymous Thanks for your reply. Still, your measure is missing overall total row value. Here is the correct measure which helps me to acheieve desired result
Hi @Venkatesh_ ,
You can try this.
Measure 4 =
var _table1=
DISTINCT('BITransactions'[ProductName])
var _table2=
DISTINCT('Sites'[Name])
var _table3=
CROSSJOIN(
_table1,_table2)
var _table4=
ADDCOLUMNS(
_table3,"1",[Predicted Year Income 1],
"2",[Predicted Year Income 2])
var _table5=
ADDCOLUMNS(
_table4,"3",[1] - [2])
var _value=
SUMX(
FILTER(
_table5,[ProductName]=MAX('BITransactions'[ProductName])),[3])
return
IF(
HASONEVALUE(
'Sites'[Name]),[Proj. Annual Var],
IF(
HASONEVALUE(BITransactions[ProductName]),_value))
Clara Gong
Hi @Venkatesh_ ,
Thanks for the reply from @fahadqadir3 , please allow me to provide another insight:
It seems that it may be a problem with the measure total. You can use the ISINSCOPE function to control different levels to show different results.
Measure =
IF(ISINSCOPE(financials[Product]),"aaa",IF(ISINSCOPE('financials'[Country]),"bbb"))
In addition, these links may be helpful to you:
Dealing with Measure Totals - Microsoft Fabric Community
Measure Totals, The Final Word - Microsoft Fabric Community
If your Current Period does not refer to this, please clarify in a follow-up reply.
Clara Gong
@Anonymous It seems like I cannot use the INSCOPE function in my measure, attaching the snap for your reference
Hi @Venkatesh_ ,
This function is ISINSCOPE instead of INSCOPE. Also, please check whether the difference between your two numbers in the parent level is 0. If it is 0, you need to rewrite the calculation for it and then use the ISINSCOPE function to return its value.
Clara Gong
Can you send me the revised measure please? I can't achieve yet.
Hi @Venkatesh_ ,
Can you share sample data and sample output in table format? Or a sample pbix after removing sensitive data. We can better understand the problem and help you.
Clara Gong
Hi @Anonymous Attaching the PBIX sample file link for your reference. It says the problem with the matrix visual on Proj annual variance and variance on sell price. You wont see any sub total or total rows and if you see they are adding incorrect results. Thanks.
Sample PBI link:
https://drive.google.com/drive/folders/1pXfcLfmEDZ0uaRRncSCeBIIBFSaVR_TI?usp=sharing
@Anonymous any update on this problem please?
@Venkatesh_ In your screenshot, last line (highlighted in red) is a SUBTOTAL VALUE or a site name VALUE ? I didn't see subtotal in your image attached, share a sample dataset or clear picture. Thank you
@fahadqadir3 First row is the sub total(row) of the product, attaching the full matrix visual, the grand total also shows zero for the meaures above, If you see the first line, It should result approx "90.20" = (-185+90.48), same follows for variance of avg sell price as well.
| 9 | |
| 6 | |
| 3 | |
| 2 | |
| 1 |
| 21 | |
| 14 | |
| 11 | |
| 5 | |
| 5 |
