Need help in dax while using matrix visual - Row total is not giving me the correct result
- 2 years ago
Anonymous Thanks for your reply. Still, your measure is missing overall total row value. Here is the correct measure which helps me to acheieve desired result
Proj. Annual Var =VAR PYI1 = [Predicted Year Income 1]VAR PYI2 = [Predicted Year Income 2]VAR Result =IF(ISINSCOPE(Sites[Name]) && ISINSCOPE(BITransactions[ProductName]),PYI1 - PYI2,SUMX(SUMMARIZE(BITransactions,Sites[Name],BITransactions[ProductName],"Diff", [Predicted Year Income 1] - [Predicted Year Income 2]),[Diff]))RETURN Result
Hi Venkatesh_ ,
Thanks for the reply from fahadqadir3 , please allow me to provide another insight:
It seems that it may be a problem with the measure total. You can use the ISINSCOPE function to control different levels to show different results.
Measure =
IF(ISINSCOPE(financials[Product]),"aaa",IF(ISINSCOPE('financials'[Country]),"bbb"))
In addition, these links may be helpful to you:
Dealing with Measure Totals - Microsoft Fabric Community
Measure Totals, The Final Word - Microsoft Fabric Community
If your Current Period does not refer to this, please clarify in a follow-up reply.
Clara Gong
Anonymous It seems like I cannot use the INSCOPE function in my measure, attaching the snap for your reference
Hi Venkatesh_ ,
This function is ISINSCOPE instead of INSCOPE. Also, please check whether the difference between your two numbers in the parent level is 0. If it is 0, you need to rewrite the calculation for it and then use the ISINSCOPE function to return its value.
Clara Gong
- Venkatesh_2 years ago
Can you send me the revised measure please? I can't achieve yet.
Hi Venkatesh_ ,
Can you share sample data and sample output in table format? Or a sample pbix after removing sensitive data. We can better understand the problem and help you.
Clara Gong
