Unknown_1's avatar
Unknown_1
1 year ago
Need Help in Power BI visualisation
Hi Team,
I have created this visual in power bi. I want to add the actuals which is a calculated measure against each of the business unit($m @ FY25 plan rate)
For eg against Lending what is the actual value of it and for Payments and so on.
How can that be achieved, appreciate your help.
    1 year ago
    Hi  Unknown_1 ,
    I created some data:
    If you want to calculate for each [business unit], you can consider placing the [business unit] in Column in the matrix visual and it will be calculated based on the grouping of fields placed in Row and Column.
    1. Create measure.
    I don't know your calculation logic, I created my own custom logic, [Plan%] to find the business unit grouping percentage of each Group, you can use filter() function in the measure to define the grouping logic calculation in it
    Plan% =
    DIVIDE(
        [Plan],
    SUMX(FILTER(ALL('Table'),'Table'[Group]=MAX('Table'[Group])),[Value]))
    2. Result:
    If the above results do not meet your expectations, you can express the expected results in the form of a picture, we can better help you!
    Liu Yang
1 Reply
    Hi  Unknown_1 ,
    1. Create measure.
    Plan% =
    DIVIDE(
        [Plan],
    2. Result:
    Liu Yang
