Max function showing wrong. Need help for Powerbi Matrix total
Hello everyone, I need your support to solve and understand issues in my DAX. I have a transactionDB of all bank transaction like below:
| date | company | type | Source | Bank | amount |
| 01-Apr-22 | Company 1 | Credit | Bank | Bank A | 10000 |
| 01-Apr-22 | Company 1 | Credit | Bank | Bank B | 10000 |
| 01-Apr-22 | Company 1 | Debit | Bank | Bank B | 500 |
| 01-Apr-22 | Company 2 | Credit | Bank | Bank C | 10000 |
| 01-Apr-22 | Company 2 | Credit | Bank | Bank D | 10000 |
| 01-Apr-22 | Company 2 | Debit | Bank | Bank C | 10000 |
| 02-Apr-22 | Company 1 | Debit | Bank | Bank A | 3000 |
| 02-Apr-22 | Company 1 | Debit | Bank | Bank B | 1000 |
| 03-Jun-22 | Company 2 | Credit | Bank | Bank D | 30000 |
| 03-Apr-22 | Company 1 | Credit | Bank | Bank A | 5000 |
| 03-Apr-22 | Company 2 | Credit | Bank | Bank C | 60000 |
| 03-Apr-22 | Company1 | Debit | Bank | Bank A | 2000 |
| 03-Apr-22 | Company 2 | Debit | Bank | Bank C | 10000 |
| 03-Apr-22 | Company 2 | Debit | Bank | Bank D |
I want to build a Dashboard with Matrix like below.
Users wants to see today (slider date 3/06/2022)
1. Opening balance of 03/06/2022 (sum of all debit - credit as of of 2/06/2022)
2. Sum of credit happened on 03/06/2022
3. Sum of debit happened on 03/06/2022
4. Closing balance of 03/06/2022
If the user changes the date slider to 2/06/202, they will see above status as of 02/06/2022
Solution
1. Opening Measure (This is working fine with slider and all values)
FILTER(ALLSELECTED(transactionDB[date]),
ISONORAFTER(transactionDB[date],MAX(transactionDB[date])-1,DESC)))
2. Credit (Matrix is showing wrong calculation)
I want to show the credit happened in Slider date ie. 03/06/2022. It is not working as expected.
3. Debit(Matrix is showing for wrong calculation)
I want to show the debit happened in Slider date ie. 03/06/2022. It is not working as expected.
4. Ending balance (This is working fine with slider and all values)
Please help to solve this issue. I understand that using max function will summarize the value based on maximum date filtered within its context. But i would like to show the debit or credit happened for that particular date as per date slider
ChandeepChhabra GuyInACube johnt75 tamerj1
- amitchandak
nizaeros , with help from a date table you need measure like
[Intial Balance] + CALCULATE(SUM(Table[Credit]),filter(date,date[date] <=maxx(date,date[date]))) - CALCULATE(SUM(Table[Debit]),filter(date,date[date] <=maxx(date,date[date])))
Closing Bal =
[Intial Balance] + CALCULATE(SUM(Table[Credit]),filter(date,date[date] <=maxx(date,date[date]))) - CALCULATE(SUM(Table[Debit]),filter(date,date[date] <=maxx(date,date[date]))) - v-yanjiang-msft
Hi nizaeros ,
According to your description, I create a sample the same with yours.
But the Opening balance return nothing when select 2022/6/1-2022/6/3.
Most of your date are from April, I don't know why you select June in the slicer, if your sample data is not complete, please show the data related to the expected result. Then we can reproduce your problem.
Just from the formula, you can try to modify it like this:
Credit = CALCULATE ( SUM ( transactionDB[credit] ), FILTER ( ALLSELECTED ( transactionDB[date] ), transactionDB[date] = MAXX ( ALLSELECTED ( transactionDB[date] ), transactionDB[date] ) ) )Best Regards,
Community Support Team _ kalyjIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
