6 years agoNot applicable
MAX function with Text column doesn't work in Live Connection SSAS Tabular
Hi Experts, I have a trouble using DAX function: MAX. I want to get a unique value from Text column to use switch to use different calculation for each category in one measure. In Power BI D...
If you are sure that in the context there'll be only one value anyway... why not use SELECTEDVALUE?
Best
D
Best
D
Do you have experience that worked the SELECTEDVALUE function in SSAS?
Do you mean my expression:
TEST_:=
IF(MAX('FactPayment'[Category], "SUM_PAY_AMT_KRW") , [Payment_KRW (AS-IS)], BLANK())
change into like below...?
IF(SELECTEDVALUE('FactPayment'[Category], "SUM_PAY_AMT_KRW") , [Payment_KRW (AS-IS)], BLANK())
I do not have any knowledge with the function, if my expression with SELECTEDVALUE is wrong, please correct it.
I tried MAX, LASTNONBLANK, FIRSTNONBLANK... but all of the function made error in SSAS...
- Anonymous6 years agoNot applicableWhether you can use this function or not depends on the version of the product you use. Please find the documentation and examples of usage here:
https://dax.guide/selectedvalue/
Best
D
