6 years agoNot applicable
MAX function with Text column doesn't work in Live Connection SSAS Tabular
Hi Experts, I have a trouble using DAX function: MAX. I want to get a unique value from Text column to use switch to use different calculation for each category in one measure. In Power BI D...
the way you wrote it, you perhaps tried to do this instead
e.g. Measure = IF(MAX('Table'[TextColumn]) = "A", Value, Blank())
there was an extra ")"
don't know if it helps
Hi Anonymous ,
Based on my test using Power Bi version : 2.80.5803.1061 64-bit .I cannot reproduce your issue here. Could you please update your Power bi desktop and check again?
Or we can try this formula.
IF(value('Table'[TextColumn]) = "A", Value, Blank())
Thanks for your kind reproduce with image, Frank.
However my issue is when I'm working with SSAS live connect, not just Power BI alone.
The same DAX expression works in Power BI, but when the data comes from SSAS tabular mode in Live connection, the expression makes error.
Looks weird.
