Anonymous's avatar
4 years ago
Help with Vlookup using same column for search value and column value
Hi everyone,
I cant get my head around this problem in Power BI. I´m adding a new column to my table and want to check lookup if the same ID has value in both the column "F" and "L", but on different rows.
For example: The added column "Both F and L" should check if the same ID in the table has a value in both "F" and the "L" column, and if the same ID exist in the the table with the value "1" in both "F" and "L" then return 1 in the "Both F and L" column. I want to check if the customer has bought both the F and L product, but in different time periods.
My problem is I cant get the vlookup to work when using the same column for evertyhing (search value and search column). Dont want to create a new table for this.
IDFLBoth F and L
1101
2010
3100
1011
Niclas
  • tamerj1's avatar
    tamerj1
    4 years ago
    Please try
    IF (
        TableName[ID]
            IN VALUES ( TableName[L] )
                && TableName[ID] IN VALUES ( TableName[F] ),
        1,
        0
  • Anonymous
    Please use
    VAR CurrentIDTable =
        CALCULATETABLE ( TableName, ALLEXCEPT ( TableName, TableName[ID] ) )
    VAR FValue =
        SUMX ( CurrentIDTable, TableName[F] )
    VAR LValue =
        SUMX ( CurrentIDTable, TableName[L] )
        IF ( FValue > 0 && LValue > 0, 1, 0 )
  • tamerj1's avatar
    tamerj1
    Ok but why the result for the first ID 1 is 0?
      Sorry, misstake from me
      • tamerj1's avatar
        tamerj1
        Please try
        IF (
            TableName[ID]
            1,
            0
