bibro5's avatar
bibro5
1 year ago
Help with DAX for Running Total Subtractions
I'm working with two tables, **Inventory** and **Transactions**, and I'm trying to create a DAX measure that provides a running total of subtractions. Here's the scenario: Inventory     ID ...
  • quantumudit's avatar
    quantumudit
    1 year ago
    Hello bibro5
    To obtain the correct row totals, we modify the formulas as follows:
    Modify the "Available Quantity" formula as follows:
    Available Quantity =
    IF ( [Total Quantity Sold] <> BLANK (), SUM ( Inventory[Quantity] ) )
    Modify the "Running Quantity Sold" formula as follows:
    Running Quantity Sold =
    VAR _remainingQty =
            [Available Quantity] - [Total Quantity Sold],
            FILTER (
                ALL ( Transactions ),
                Transactions[ID] = MAX ( Transactions[ID] )
                    && Transactions[DATE] <= MAX ( Transactions[DATE] )
    VAR _runningQuntity =
        IF (
            _remainingQty >= 0,
            [Total Quantity Sold] + _remainingQty
    VAR _handlingOversale =
        IF (
            _runningQuntity <= 0
                && [Total Quantity Sold] <> BLANK (),
            0,
            _runningQuntity
        IF(ISINSCOPE(Transactions[DATE]), _handlingOversale, [Available Quantity])
    In the following animation, you can observe that we are achieving the desired results at both the total level and the individual ID/Type leve. While I understand you do not wish any slicer, please note that the formula is robust to handle it should you decide to utilize one in the future.
    I am also attaching the Power BI file for your reference.
    I hope have answered your question correctly. However, if there is still any doubt, please do not hesitate to let me know.
    Udit
    If this post helps, then please consider Accepting it as the solution to help the other members find it more quickly.
    Appreciate your Kudo 👍
    🚀 Let's Connect: LinkedIn || YouTube || Medium || GitHub
    Visit My Linktree: LinkTree
    Proud to be a Super User
