mazingazeta's avatar
mazingazeta
5 years ago
Help with DAX Measure (LOOKUPVALUE, TOPN, RANKX; MAX, Groupby)
Hello, I have the following question: I need the NAME of the Agent with the most amount per Customer. (the result should be : a - Hannes, b - fritz, c - mike). I tried and thinked a lot of different measures (TOPN,Lookup, MAX, Rankx) ...but didnt get it right, anyone an idea?
Customer - Agent - Amount
a               -  fritz   -  1o
a                - fritz - 1
a                - hannes - 20
a                - hannes 3
b               - fritz    - 5
b               -  mike - 3
b                - hannes -1
c                - mike - 4
c                 - fritz - 1
  • mazingazeta ,
    You can use these measures:
    _TotalAgent = SUMX(SUMMARIZE('Table', 'Table'[Agent], "Total", SUM('Table'[Amount])), [Total])
    _Rank = IF(HASONEVALUE('Table'[Agent]), RANKX(ALL('Table'[Agent]), [_TotalAgent],,DESC), BLANK())
  • AlB's avatar
    AlB
    Hi  mazingazeta
    1. Place Customer in a table visual
    2. Create this measure and place it in the visual
    Measure =
    CONCATENATEX (
        TOPN (
            1,
            Table1,
            CALCULATE ( SUM ( Table1[Amount] ), ALLEXCEPT ( Table1, Table1[Agent] ) ), DESC
        Table1[Agent],
    Please mark the question solved when done and consider giving a thumbs up if posts are helpful.
    Cheers
  • camargos88's avatar
    camargos88
    mazingazeta ,
