Hi all,
I’m working on a Power BI report where I have two values (Planning and Prognose) with fairly complex measures behind them. These values are spread across a series of weeks and companies. For each week and company combination, I want to calculate the maximum value between the two (using the MAX function), which works well so far. However, now I need to calculate the cumulative total based on the result of that MAX function, so it "grows" as the weeks progress.
For example, my data looks like this:
Company | Week | Planning | Prognosis | Max | Cumulative |
Company 1 | 2024w01 | 20 | 30 | 30 | 30 |
Company 1 | 2024w02 | 40 | 20 | 40 | 70 |
Company 1 | 2024w03 | 40 | 50 | 50 | 120 |
Company 2 | 2024w01 | 30 | 20 | 30 | 30 |
Company 2 | 2024w02 | 60 | 30 | 60 | 90 |
Company 2 | 2024w03 | 40 | 50 | 50 | 140 |
Company 3 | 2024w01 | 90 | 20 | 90 | 90 |
Company 3 | 2024w02 | 60 | 50 | 60 | 150 |
Company 3 | 2024w03 | 20 | 70 | 70 | 220 |
The challenge I’m facing is how to calculate the Cumulative column. For each company, I want the cumulative sum to add up the maximum value for each week.
Here’s the approach I’ve tried:
I created a measure to get the max value for each week and company, which works as expected.
Then, I tried using a DAX formula to accumulate the max values, but I’m running into issues where the cumulative sum doesn’t update correctly across different companies.
Can anyone help me with the right DAX formula for this cumulative calculation?
Thanks in advance!
Thank you for your response and excuse me for my late reply. I've tried this, but it seems that my Prognosis measure isn't working in the context unfortunately. Therefore, I have decided to rework the data model in a way that better fits this purpose. I assume it will work from there, but didn't have the time to fix that yet.
Hi @CreativeEnergy,
Just a gentle reminder — has your issue been resolved? If so, we’d be grateful if you could mark the solution that worked as Accepted Solution, or feel free to share your own if you found a different fix.
This not only closes the loop on your query but also helps others in the community solve similar issues faster.
Thank you for your time and feedback!
Best,
Prasanna Kumar
Hi @CreativeEnergy,
We wanted to kindly check in to see if everything is working as expected after trying the suggested solution. If there’s anything else we can assist with, please don’t hesitate to ask.
If the issue is resolved, we’d appreciate it if you could mark the helpful reply as Accepted Solution — it helps others who might face a similar issue.
Warm regards,
Prasanna Kumar
Hi @CreativeEnergy,
Just following up to see if the solution provided was helpful in resolving your issue. Please feel free to let us know if you need any further assistance.
If the response addressed your query, kindly mark it as Accepted Solution and click Yes if you found it helpful — this will benefit others in the community as well.
Best regards,
Prasanna Kumar
assuming:
Step 1: Create a calculated column or measure for the row-wise maximum:
If you're working with measures:
MaxValue = MAX([Planning], [Prognosis])
If you're working in the data table and this can be a calculated column:
MaxValue = MAXX({[Planning], [Prognosis]}, [Value])
Step 2: Create a Cumulative Max measure:
To get a cumulative total of MaxValue per company, sorted by week:
Option A: If Week is a sortable column (like numeric week or proper date):
CumulativeMax =
VAR CurrentWeek = SELECTEDVALUE('Data'[Week])
CALCULATE(
SUMX(
FILTER(
ALL('Data'),
'Data'[Company] = SELECTEDVALUE('Data'[Company]) &&
'Data'[Week] <= CurrentWeek
Option B: If Week is a text field like 2024w01 and not sorted properly:
You’ll need to create a sortable column (e.g., "202401" as integer) for the cumulative logic to work properly. Add a column:
SortWeek =
VAR Year = LEFT('Data'[Week], 4)
VAR WeekNum = RIGHT('Data'[Week], 2)
RETURN VALUE(Year & WeekNum)
Then sort your Week column by SortWeek.
Now update the CumulativeMax measure:
DAX
CopyEdit
CumulativeMax =
VAR CurrentSortWeek = SELECTEDVALUE('Data'[SortWeek])
CALCULATE(
SUMX(
FILTER(
ALL('Data'),
'Data'[SortWeek] <= CurrentSortWeek
