Find everything you need to get certified on Fabric—skills challenges, live sessions, exam prep, role guidance, and more.
Get startedGrow your Fabric skills and prepare for the DP-600 certification exam by completing the latest Microsoft Fabric challenge.
Hi Everyone,
I have a table with CRM number, Name and Phase. I need to find max value with respect to the highest CRM number of the Quote (phase) alone. Though the name may consists of many other phases like agreement or leads but I need max value of highest number of the Quote. I have added a table with this message of how the result may look like. Thank you in advance.
I want DAX in PowerBi, I tried many other methods. Please help in this regard.
@FreemanZ
CRM | Name | Phase | Max Value |
1123 | Rahul | Agreement | |
1130 | Rahul | Agreement | |
1125 | Rahul | Agreement | |
2240 | Giva | Agreement | |
2241 | Giva | Agreement | |
2247 | Giva | Agreement | |
2250 | Giva | Quote | MAX |
2280 | Giva | Lead | |
3300 | Kicha | Quote | |
3301 | Kicha | Quote | MAX |
3302 | Kicha | Lead |
Thank you for your feedback, and please check the below picture and the attached pbix file.
Max indicator of CRM number: =
VAR _maxcrmvalue =
MAXX (
FILTER (
ALL ( Data ),
Data[Name] = MAX ( Data[Name] )
&& Data[Phase] = "Quote"
Data[CRM]
IF ( MAX ( Data[CRM] ) = _maxcrmvalue, "MAX" )
If this post helps, then please consider accepting it as the solution to help other members find it faster, and give a big thumbs up.
Please check the below picture and the attached pbix file.
The below is for creating a new column.
Max CRM number indicator CC =
VAR _maxcrmvalue =
MAXX (
FILTER (
Data ,
Data[Name] = EARLIER( Data[Name] )
Data[CRM]
IF ( Data[CRM] = _maxcrmvalue, "MAX" )
You may also try this code:
I am not sure if I understood your question correctly, but please check the below picture and the attached pbix file.
Max value of CRM number: =
IF (
HASONEVALUE ( Data[Name] ),
MAXX ( FILTER ( Data, Data[Phase] = "Quote" ), Data[CRM] )
I have a table consisting of name, CRM number and a phase where I need to find the max value of the CRM number. I have three conditions here : I want DAX in PowerBi.
If a name has only agreements in the phase then there shouldnt be any max value.
If a name consists of agreements, quotes and leads then the max value should be of the highest number of the CRM in the quote as per particular name.
If a name consists of multiple Quotes in CRM then they should be of the highest number of CRM in the quote. I have attached an example of how the value should be displayed for your refererance.
I have tried many methods but couldnt find any solution please help me in this regard.
VAR _maxcrmvalue =
MAXX (
FILTER (
ALL ( Data ),
Data[CRM]
Can I know how to add this as a column but not as a measure.
VAR _maxcrmvalue =
MAXX (
FILTER (
Data ,
Data[CRM]
Thanks this worked out as well !
This also wroked out thanks !
65 | |
46 | |
20 | |
18 | |
15 |
119 | |
41 | |
40 | |
28 | |
22 |
