dianecrz
3 years agoFrequent Visitor
DAX Delta Issue - Difference Between Dates Not Working When Amount is Zero for Maximum Date Selected
I am trying to accurately calculate the difference in the amount sold between the most recent date selected and the oldest one. I used a DAX formula to create my Delta, and when calculating the diff...
dianecrz
Hi Martin_D
The solution you provided solves the delta issue when the latest date value is blank. The screenshot below shows the results of your DAX function.
However, it is not ideal because it converts the minimum date values to negative, which works fine for the delta calculation but can be wrongly interpreted by users, since these are positive orders from July 5th.
I am considering as a second option to work on the data and insert values for dates where I do not have any order data. Please let me know if there is an easier solution.
Thank you so much!!!
Best,
Diane
