6 years agoNot applicable
Calculating difference between two time values column and finding its average
Hi Everyone, I need your help to solve a problem that I am facing. I have two columns which have time based value as shown in the picture: ...
- 6 years ago
Hi Anonymous
try a measure
Measure = format(calculate(averagex('Table',TIMEVALUE('Table'[Avg store reach time]))),"HH:MM:SS")or
Measure = format(averagex('Table',TIMEVALUE('Table'[Avg store reach time])),"HH:MM:SS")depends on business logic
az38
6 years agoCommunity Champion
Hi Anonymous
try a measure
or
Hi az38
Thank you for your help. It worked for me.
Is it ok if I can contact you for any future help?
- az386 years agoCommunity Champion
anytime. new threads, private messages, Linkedin.
the same about the Community - there are a lot of great users passionate to help you
Thank you so much for the support.
Actually I am a little new to Power BI and hence facing another problem.
I used the below measure to find the top 5 riders:
Top 5 Riders = VAR RiderRank = (RANKX(ALL(Sheet1[Rider]), [Out The Door Time], ,DESC)) RETURN IF( RiderRank <=5, [Out The Door Time], BLANK())Now I want a measure by which I can find order count done by only these riders. Now order count in a different measure:
