Anonymous's avatar
6 years ago
Calculating difference between two time values column and finding its average
Hi Everyone,
I need your help to solve a problem that I am facing.
I have two columns which have time based value as shown in the picture:
I found their difference using the formula    Duration.ToText([Reached Merchant]-[Assigned At])), I got the result as follows:
Now in order to find average of "Avg store reach time", I made a new measure as follows:
Measure = FORMAT(AVERAGE(Sheet1[Avg store reach time]),"HH:MM:SS")
Now instead of getting an average of the column "Avg store reach time" I am getting the below error:
Please help me with this. Thank you
RK
  • Hi Anonymous
    try a measure
    Measure = format(calculate(averagex('Table',TIMEVALUE('Table'[Avg store reach time]))),"HH:MM:SS")
    or
    Measure = format(averagex('Table',TIMEVALUE('Table'[Avg store reach time])),"HH:MM:SS")
    depends on business logic
  • az38's avatar
    az38
    Hi Anonymous
    try a measure
    or
      Hi az38
      Thank you for your help. It worked for me.
      Is it ok if I can contact you for any future help?
      • az38's avatar
        az38
        anytime. new threads, private messages, Linkedin.
        the same about the Community - there are a lot of great users passionate to help you
  • Hi Anonymous ,
    "Avg Store reach time" is of STRING datatype because your calculation as below returns a text type of value:
    Pragati
