Calculating difference between two column values in matrix
- 3 years ago
Please try
MoM Variance =
VAR CurrentValue = [No. of Orders]
VAR CuurentYearMonth =
MAX ( 'Date'[YearMonthNum] )
VAR PreviousValue =
[No. of Orders],
'Date'[YearMonthNum] = CuurentYearMonth - 1,
ALL ( 'Date' )
IF (
NOT ISBLANK ( PreviousValue ),
DIVIDE ( CurrentValue - PreviousValue, CurrentValue )
) - 3 years ago
Curtw01
You should be using a YearMonthNum column which is supposed to be a sequential number such as a dense rank. For example for Jan. 2023 you cannot minus one from 202301 to obtain 202212. Rather you will obtain 202300 which basically has no value in your date table. Therefore, the YearMonthNum is different than the YearMonth column which can start from 1 for example to refer to the very first month in your table and keeps adding 1 for each month after that. You can create such column usingRANKX (
'Date',
'Date'[YearMonth],, -- In the form of YYYYMM like 202307
ASC,Dense
Yes, in my real world scenario it would be MonthYear in the columns of the matrix and I have a MonthYearNum column in my date table in which to rank.
Please try
MoM Variance =
VAR PreviousValue =
[No. of Orders],
ALL ( 'Date' )
IF (
- Curtw013 years agoFrequent Visitor
Had to tweak slightly but that worked a treat! Thank you very much!
Revisiting this and hoping you could potentially help further.
When displaying this measure in the matrix it does not seem to show any January values for any year? Any ideas how to get around this?
- tamerj13 years ago
Curtw01
'Date',
ASC,Dense
)- Curtw013 years agoFrequent Visitor
Ahh yes that now makes sense, appreciate your help once again!
