Curtw01's avatar
Curtw01
3 years ago
Calculating difference between two column values in matrix
Hi,   First ever post to the forum (I believe this is the correct place to post) so excuse me if there is too much/too little information provided.    I have a requirement whereby I need to displ...
  • tamerj1's avatar
    tamerj1
    3 years ago
    Curtw01
    Please try
    MoM Variance =
    VAR CurrentValue = [No. of Orders]
    VAR CuurentYearMonth =
    MAX ( 'Date'[YearMonthNum] )
    VAR PreviousValue =
    [No. of Orders],
    'Date'[YearMonthNum] = CuurentYearMonth - 1,
    ALL ( 'Date' )
    IF (
    NOT ISBLANK ( PreviousValue ),
    DIVIDE ( CurrentValue - PreviousValue, CurrentValue )
  • tamerj1's avatar
    tamerj1
    3 years ago
    Curtw01
    You should be using a YearMonthNum column which is supposed to be a sequential number such as a dense rank. For example for Jan. 2023 you cannot minus one from 202301 to obtain 202212. Rather you will obtain 202300 which basically has no value in your date table. Therefore, the YearMonthNum is different than the YearMonth column which can start from 1 for example to refer to the very first month in your table and keeps adding 1 for each month after that. You can create such column using
    RANKX (
    'Date',
    'Date'[YearMonth],, -- In the form of YYYYMM like 202307
    ASC,
    Dense
