Calculating Leaves Based on Project - Data Model (Schema) Help!
Hi Everyone,
I have encountered a situation where i cant seem to find logic for a solution. so here is the sinario
I have 3 Tables: Date, Attendance and Project.
Here is the model I have made.
Basically I want to track Number of Leaves. ([Leaves Count] from Attendance Table) based on the project's duration.
For example. The Project A starts in May and Ends in June. I want to show the Resources (Employee ID) That worked on That project and Their [Leaves Count] during the Project [Actual SD] and [Actual ED]
At this point it shows all days from January when I select the Project which is not the case as project starts in May.
It might be the case in the terms of filter direction and showing scaler values in the table form, but I can't seem to wrap my head around it. I have shared the link of zip file that contains PIBX and Data file as well, I am trying to work around the solution so far no success. 😞 a help would be great!
Hi fahadkhan ,
In fact, the relationship you established between 'Attendance' and 'Project' is inactive, this relationship is not actually in effect, you can change the relationship to the following:
For more detailed information, please refer to:
Model relationships in Power BI Desktop
Active vs inactive relationship guidance
Jianbo Li
1 Reply
- v-jianboli-msft
Hi fahadkhan ,
Jianbo Li
