Calculating Leaves Based on Project - Data Model (Schema) Help!
- 4 years ago
Hi fahadkhan ,
In fact, the relationship you established between 'Attendance' and 'Project' is inactive, this relationship is not actually in effect, you can change the relationship to the following:
For more detailed information, please refer to:
Model relationships in Power BI Desktop
Active vs inactive relationship guidance
Jianbo Li
Hi fahadkhan ,
Jianbo Li
