Auto-exist and duplicated measure problem when using two Dim tables in a visual
- 2 years ago
you don't really need DAX for that. But a small change to the data model is required.
- 2 years ago
But in reality, in my real data, I don't know the office to which an interviewer belongThen you cannot include both in the same visual.
Hi lbendlin ,
Thanks for your reply. Well, I made a mistake by adding the field Office ID to the Interviewer table. I did that only to show clearly that each Interviewer belong to an office. But in reality, in my real data, I don't know the office to which an interviewer belong, and I can only rely on the fact table.
So in the specifc business scenario I'm refering to, what would you suggest?
I'm sure there are a lot of scenario like this one, and I guess these is a relatively easy solution to fix this problem, but can't find it...
Thank you very much,
- Nyansapo2 years agoFrequent Visitor
Hi lbendlin ,
Thanks for the input, I really thought it was possible, I thought there would be a way to get this information from the fact table (without explicitly populating the dim table with it), but now that I think about that, your answer make sense.Thanks a lot for your time and information, you got me out of my misunderstanding! Really appreciate! 🙂
