Auto-exist and duplicated measure problem when using two Dim tables in a visual
- 2 years ago
you don't really need DAX for that. But a small change to the data model is required.
- 2 years ago
But in reality, in my real data, I don't know the office to which an interviewer belongThen you cannot include both in the same visual.
Hi lbendlin ,
Thanks a lot for your quick reply! Your solution definitly works in this context, but here is my question : How if I would not have had Office ID in my Interviewer dim table? Let say we wouldn't know who is working where, but would only have the actual transactions in the fact table. I would like to be able to set my measure or my visual so that Power BI do not create row conbinations of Interviewers and Offices that do not exist in the fact table. This is a situation I often encounter. Is there any ways to do that?
I can of course extract the data from the fact table and feed it into my dim table, but would really like to avoid this kind of manipulation.
Thank you very much! 🙂
- lbendlin2 years ago
The data model needs to follow the business scenario. If your business scenario changes then you need to adjust your data model accordingly.
- Nyansapo2 years agoFrequent Visitor
Hi lbendlin ,
Thanks for your reply. Well, I made a mistake by adding the field Office ID to the Interviewer table. I did that only to show clearly that each Interviewer belong to an office. But in reality, in my real data, I don't know the office to which an interviewer belong, and I can only rely on the fact table.So in the specifc business scenario I'm refering to, what would you suggest?
I'm sure there are a lot of scenario like this one, and I guess these is a relatively easy solution to fix this problem, but can't find it...
Thank you very much,
