Get your discountCustom Visuals Ideas will be in read-only beginning Friday, Feb. 28 as we prepare to move these ideas to the new Fabric Ideas.
currently this works fine when refreshing over power bi desktop but its a limitation on the power bi service that give a SSO authentication error and doesnt allow to refresh (this its actually a noted limitation on power bi dataset direct query.
