SwanCaillaud
Export Power Apps custom visual in Power BI dashboard with Power Automate
Hi all,
I've got a Power BI dashboard, in which I integrated a Power Apps (Power Apps custom visual).
When I manually export this dashboard in PDF, the Power Apps custom visual is well exported.
But, when I use Power Automate, with Power BI connector, and "Export to file for Power BI Reports" action, the Power Apps custom visual is not exported, and replaced by the sentence "This visual does not support exporting".
This sentence is normally used for non certified visuals (note: non certified visual can't be manually exported, but here the Power Apps custom visual can).
According to Microsoft support, this behavior is due to the fact that embedded analytics doesn't support Power Apps custom visual.
My question is: Do you know if it is planned that embedded analytics supports Power Apps custom visuals? If yes, when? If no, do you know how I could automate the export to PDF of a Power BI dashboard with a Power Apps custom visual?
Thanks in advance,
Swan
0 REPLIES 0
