Pronocalme
1 year agoFrequent Visitor
Web V2 connection problem
Hello everyone ! I've created a dashboard using a data source from an advanced Web connection, but when I publish this dashboard, the connection becomes a Web connection (and not Web V2 as it sho...
- 1 year ago
I recreated my report from scratch and my problem solved itself, without any change in PowerQuery. Thanks for the help !
lbendlin
1 year ago2. In the "Advanced" settings, ensure that you select "Web V2" as the connection type. If you do not see this option directly, it might be configured within the API key or authentication settings.
News to me, and not supported by your screenshot. Are you using a prerelease version?
v-hashadapu
1 year agoHi lbendlin, Thanks for your reply. Apologies for not explaining it clearly.
As of October of 2021, Power BI Desktop uses Microsoft Edge WebView2, by default, for OAuth authentication for all connectors. so, i can't share a screenshot showing me selecting Web V2. But as i am not sure which version Pronocalme is using, i gave two ways to ensure Web V2 is used.
Please refer the below documentation:
https://learn.microsoft.com/en-us/power-query/oauth-edge-chromium
