Pronocalme
1 year agoFrequent Visitor
Web V2 connection problem
Hello everyone ! I've created a dashboard using a data source from an advanced Web connection, but when I publish this dashboard, the connection becomes a Web connection (and not Web V2 as it sho...
- 1 year ago
I recreated my report from scratch and my problem solved itself, without any change in PowerQuery. Thanks for the help !
v-hashadapu
1 year agoHi Pronocalme , thank you for reaching out to the Microsoft Fabric Community Forum.
Please consider below:
- Ensure that you are using the correct connection type. When setting up the connection in Power BI, make sure you select "Web V2" instead of just "Web”.
- Try recreating the Web V2 connection from scratch. Go to "Get Data" > "Web" > "Advanced" and ensure you select "Web V2" as the connection type.
- When setting up the Web V2 connection, ensure you have the correct URL and headers, including the Bearer token. Double-check the token and ensure it is valid.
- When publishing the report, double-check the publish settings to ensure the connection type remains as Web V2.
- Ensure that you have the necessary permissions to use the Web V2 connection and that the API endpoint you are connecting to supports Web V2.
- If your Bearer token is dynamic or sensitive, consider using a Tableau parameter to store and manage it securely. This parameter can then be used within the Web V2 connection string.
- Verify that your Tableau Server environment is configured correctly to support Web V2 connections and any required authentication methods.
- Review the Tableau Server logs for any error messages related to the Web V2 connection or the published workbook.
- Make sure your Power BI Desktop is up to date. Sometimes, updates include fixes for such issues.
If this helps, please consider marking it 'Accept as Solution' so others with similar queries may find it more easily. If not, please share the details.
