Timeout Issues in Power BI - Need Help Resolving Visual Loading Error
- Anonymous2 years ago
Hi Masakinka ,
Thanks for the reply from SaiTejaTalasila , please allow me to provide another insight:
DirectQuery sends all requests to the source database, so the time it takes for a visual to refresh depends on how long it takes the underlying source to return results. Five seconds or less is the recommended response time to receive the data requested by a visual. Refresh times longer than 30 seconds create an unacceptably poor experience for people using the report. In the Power BI service, queries that take longer than four minutes time out and users receive an error. This limit is designed to prevent issues caused by long execution times. You should only use DirectQuery for sources that can provide interactive query performance.
You can start diagnosing performance issues in Power BI Desktop, not in the Power BI service. Performance issues are often based on the performance of the underlying source. It's easier to identify and diagnose issues in a more isolated Power BI Desktop environment.
More detailed information is available in the documentation:
Use DirectQuery in Power BI Desktop - Power BI | Microsoft Learn
DirectQuery in Power BI - Power BI | Microsoft Learn
If your Current Period does not refer to this, please clarify in a follow-up reply.
Clara Gong
Hi Masakinka ,
It looks like the backend which are generated by your visuals on service are taking more time to execute.
Sai Teja
Hi SaiTejaTalasila,
Thank you for your input. I understand that the backend processes for my visuals are taking longer than expected. Could you advise if there's a way to adjust the timeout settings specifically for DirectQuery in the Power BI service? Any guidance on where these settings might be managed within the Power BI portal or if there are other best practices to handle such timeouts would be greatly appreciated.
