Semantic model uses default data connection - semantic model connecting to data warehouse
- 1 year ago
torishriver To fix this error just follow the below steps
1. Go to Dataset -> Settings
2. Under the Settings you can find Gateway and Cloud Connections
3. Click Create Connection
4. Under here you have to create a new connection and provide your SQL Server string and your credentials, authenticate it and click Create (located at the bottom)
5. Once created go back to your dataset settings and under Gateway and Cloud Connections choose"New_Connect" (in my case)
6. Now you should be able to refresh the model
Jai
Hi torishriver , Thank you for reaching out to the Microsoft Community Forum.
We find the answer shared by Jai-Rathinavel is appropriate. Can you please confirm if the solution worked for you. It will help others with similar issues find the answer easily.
Thank you Jai-Rathinavel for your valuable response.
