Problem with add admin to Power BI Gateway - AAD Application
I need help. I try add my AAD Application ( https://portal.azure.com/#view/Microsoft_AAD_RegisteredApps/ApplicationsListBlade ) and created here: https://app.powerbi.com/embedsetup/UserOwnsData to Power BI Gateway admin. In gateway Manage users not found application, only users.
I need add AAD Application as Admin, becouse needed use this call: https://learn.microsoft.com/en-us/rest/api/power-bi/gateways/get-gateways and https://learn.microsoft.com/en-us/rest/api/power-bi/gateways/get-datasources . Now i get empty list for get gateways, and "PowerBINotAuthorizedException" when try get datasources.
- Anonymous4 years ago
I found a solution. You should use PowerShell version 7 minimum and the command:
https://learn.microsoft.com/en-us/powershell/module/datagateway/add-datagatewayclusteruser?view=datagateway-ps
- AnonymousNot applicable
https://learn.microsoft.com/en-us/powershell/module/datagateway/add-datagatewayclusteruser?view=datagateway-ps - AnonymousNot applicable
Hi Anonymous ,
Please try to set the API permissions for AAD Application in the Azure Portal.
For more details, you can read related document: Quickstart: Configure an app to access a web API - Microsoft Entra | Microsoft Learn
Best regards,
Community Support Team_ Binbin Yu
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.- AnonymousNot applicable
My AAD app in "Power BI Service" group has full permission. Are you talking about a specific permission in others group? I search "gateway" and nothing found in others type permission.
I need AAD app in here:Note: https://learn.microsoft.com/en-us/power-bi/connect-data/service-gateway-data-sources#manage-users
