Problem refreshing Power bi
- 2 years ago
which option did you choose when downloading?
in order to see the power query you need to downalod the report and the semantic model not the live query report only.
if you chose "a copy of the report and data" and you get a live connected report it means semantic model (and M query) is somewherelse.
you can verify if your report was originally a live connected one looking to the lineage view in power bi service.
are you sure you haven't queries in it?
in power query, table = query
Yeah, like o load the file i downloaded and press "transform data", up comes "A directquery connection is required" so i press add a local model.
Then its shown like this.
- R1k912 years ago
- Jakob1232 years agoFrequent Visitor
Thanks a lot guys! it now works and updates as intened 🙂 Could not have done it without you ❤️
My report is not refreshing the data. Someone know why? When I click on data and select the table to do a refresh, nothing is happening.
