8 years agoNot applicable
Power Shell Invoke-PowerBIRestMethod -Method Post failing
Hi, I'm trying to create script that will refresh some datasets through Power BI API. I have registered App in Active Directory and gave it almost every permissions possible for Power BI Service (o...
Hi Gilbert,
thanks for your reply. App is registered in AD with all permissions possible. Is there something different (perhaps on tetant level) that can override them?
GilbertQ
8 years agoHi there
I would suggest making sure at the top where it says"Application Permissions you got that set to what is shown below.
where can I get this screen and configure the permission ? I am service admin.
- GilbertQ6 years ago
Hi there
The screenshot above is from Azure Active Directory.
You will have to log into https://portal.azure.com and then active Directory and then App Registrations.- Anonymous6 years agoNot applicable
Power BI embed is the only thing I can see at the moment. what does it mean ? the power bi service is not even registered in Azure ?
