Power point exportation with problems
I am trying the solution you provide, and of course is really a good idea.
Being essential for me the download of the dashboard of Google Analytics data I tried this function, and unfortunately, the ppt file that has generated has some data field as images that are too small to be read by a human eye, or some field is blank, and the graphs are divided into two pieces.
Do you think it is possible to fix these problems?
If you need I can forward you what I obtained, in order to let you understand better.
Best regards.
Based on my test, the visual that in exported PPT has the same size as that in your Power BI report. And we can resize the image size in PPT. If your report height extend the height of PPT, then it will be divided into tow pieces.
Currently, Export to PPT is a preview feature, If you have any concern on this feature, you can submit your idea on the link below. If this feature was mentioned by mulitple users, product team will consider to add this feature to next release.
https://ideas.powerbi.com/forums/265200-power-bi-ideasRegards,
Charlie Liao
1 Reply
- v-caliao-msft
Charlie Liao
