Power Point Export with Current Values not Working
I am having issues to export to Power Point reports published in Power BI Service with the current values.
In my case, I have two reports with bookmarks, and even when selecting export with current values, the export displays the values with the default bookmark, and not the one selected (current).
Is it a Power BI Service issue? any hints on how to solve this?
Thank you very much.
1 Reply
- Sahir_Maharaj
Hi brunaguimaraes,
It's possible that the issue with exporting Power BI reports with the current values is a known limitation in Power BI Service. However, there are a few steps you could try to resolve the issue:
Ensure that the bookmark is saved and that the correct view is selected before exporting the report.
Try exporting the report as a PDF instead of PowerPoint, as this may provide more accurate results.
If the issue persists, you could also try to recreate the report or use a different export format, such as an Excel file.
