1 year agoNot applicable
Power Bi Problems with Schedule Refresh
Hello, I created a Power BI report in the Power BI Developer app. My data source is a folder containing an Excel spreadsheet of the same format. Each workbook is on a different day, but my creden...
- 1 year ago
Hi Anonymous ,
Yes, you will need a Gateway setup and the path to your Excel file added as a Data Source. See this article for using a Gateway:
Guidance for deploying a data gateway for the Power BI service - Power BI | Microsoft Learn
And, along with the links Isent above, this is another helpful article:Add or remove a gateway data source - Power BI | Microsoft Learn
v-hashadapu
1 year agoHi @BeLocke , Just wanted to confirm if your issue has been solved. If it is, Please consider marking it 'Accept as Solution', so others with similar queries may find it easily. If it isn't please share the details.
