allanw
11 months agoPower BI Model based on Databricks Serverless SQL Warehouse refresh failure - ODBC: ERROR [HY000]
Hello, We have some Power BI semantic models that are refreshed based on data from Azure Databricks, served by Serverless SQL Warehouse compute. We have Power BI VNet gateway connection set up. ...
- 10 months ago
Hi allanw ,
Thanks for reaching out to Microsoft Fabric Community Forum.The specific error message you're seeing, ODBC: ERROR [HY000] [Microsoft][ThriftExtension] (14) Unexpected response from server, suggests that there might be connectivity issues between Power BI and your Azure Databricks SQL Warehouse.
Here are some steps and considerations that might help you resolve this issue:
- Ensure the SQL Warehouse is Running (not stopped or scaling)
- Verify Access Token used in Power BI is valid and not expired regenerate and update if needed.
- Confirm the Server Hostname and HTTP Path values are correct in the data source settings,From the gateway machine, make sure outbound HTTPS connectivity to Databricks endpoint is allowed: No firewall/proxy blocking ,Port 443 open outbound
- On the gateway machine, run an ODBC test using the same driver and token. Ensure the latest Databricks ODBC driver is installed.
- Restart the On-premises Data Gateway and ensure the data source mapping is correct and online
- Retry the dataset refresh in Power BI Service after the above validations.
Hope this helps!!
Thank You.
v-aatheeque
10 months agoHi allanw
Have you had a chance to look through the responses shared earlier? If anything is still unclear, we’ll be happy to provide additional support.
- v-aatheeque10 months ago
Hi allanw
We wanted to follow up to check if you’ve had an opportunity to review the previous responses. If you require further assistance, please don’t hesitate to let us know.
