Power BI Model based on Databricks Serverless SQL Warehouse refresh failure - ODBC: ERROR [HY000]
- 10 months ago
Hi allanw ,
Thanks for reaching out to Microsoft Fabric Community Forum.The specific error message you're seeing, ODBC: ERROR [HY000] [Microsoft][ThriftExtension] (14) Unexpected response from server, suggests that there might be connectivity issues between Power BI and your Azure Databricks SQL Warehouse.
Here are some steps and considerations that might help you resolve this issue:
- Ensure the SQL Warehouse is Running (not stopped or scaling)
- Verify Access Token used in Power BI is valid and not expired regenerate and update if needed.
- Confirm the Server Hostname and HTTP Path values are correct in the data source settings,From the gateway machine, make sure outbound HTTPS connectivity to Databricks endpoint is allowed: No firewall/proxy blocking ,Port 443 open outbound
- On the gateway machine, run an ODBC test using the same driver and token. Ensure the latest Databricks ODBC driver is installed.
- Restart the On-premises Data Gateway and ensure the data source mapping is correct and online
- Retry the dataset refresh in Power BI Service after the above validations.
Hope this helps!!
Thank You.
Note-AI helped me to format this solution.
1 Check Warehouse Status
Go to Databricks → SQL → Warehouses → Serverless warehouse.
Ensure it is running.
Disable “Auto-stop” temporarily and test refresh.
2.Test Connection from Gateway VM
On the machine hosting the Power BI VNet Gateway, run:
If the connection fails → VNet / NSG / firewall issue.
3. Update ODBC Driver
Ensure Microsoft ODBC Driver for Databricks is latest version:
Databricks ODBC Driver Download
Restart the gateway after update.
4. Check Power BI Dataset Settings
Go to Power BI Service → Dataset → Settings → Data Source Credentials.
Re-enter Databricks credentials (PAT token or OAuth).
Ensure the VNet gateway is selected correctly.
5. Enable Query Logging / Monitor
In Databricks:
SQL → Query History → Check for failed / long-running queries.
Verify if the warehouse received the query request at all.
6. Optional: Increase Gateway Timeout
Power BI VNet gateway has a timeout setting (default ~2 minutes).
For large datasets, increase the timeout or split queries.
