Power BI incremental refresh problem
Let me try and better explain the problem: I have incremental refresh setup - source is SQL (in this case SQL against a databricks spark table). When I run from the desktop, I confirm that 1 *folded* query is run with a where clause that selects AR document date/time >= RangeStart and < RangeEnd. This works perfectly - very efficient. However, when I run from the service to build the partitions (and for subsequent incremental runs), it "works", but an insane number of non-folded limit 1000 queries are fired against the source (note that I also get the folded queries). These take a long time to run and it looks like more are being sent because I have a large number of partitions. From everything I have seen, this is NOT what it's supposed to do. I am expecting to see only folded queries + the select max timestamp for the data change detection. Any ideas?
seems like it's issuing data preview queries like you would get in power query. only happens when running processing for partitions from the service (i.e., tables that aren't partitioned work fine with only the expected folded queries). Here's a visual:
- jtclabaugh5 years agoFrequent Visitor
From what I can tell, it's running a data preview query for every step in the power query script * the number of partitions. So if # of partitions is large, an insane number of these queries are run - and the source is big data/ADLS Gen 2 with spark on top
- MattKarriker25 years ago
Helper II
jtclabaugh Did you find a solution for this. We are running PBI over big data much like yourself. We have large PBI models in premium capacity with incremental refresh configured. We are also using the "Detect Data Changes" feature in hope of speeding up the daily refresh. The top 1000 queries are really affecting our refresh tuning. Did you find anyway around this issue?
- FilipK5 years ago
Resolver I
I'm also interested in a solution.
Since the timestamps are included in the index of the SQL table the incremental refresh query performing well.
The prior query (data preview) during incremental refresh from PBI service is very slow due to select top 1000 instruction
