Power BI Embed Problem
Hi Rick4him
Reference may helps you.
https://docs.microsoft.com/en-us/power-bi/developer/embedded-troubleshoot
If it doesn't help, I would suggest you open a ticket to get help from MS senior engineers.
Maggie
- Rick4him8 years ago
I reviewed those topics prior to submitting issue. The issue is different as the individual did not have a working embed application and I have had mine up for nearly a year. The issue I am having is that it will not work on any new PBIX reports. It works fine on all the older ones even if the older ones are modified. It will not work on any new report even if that report is based on one that works as in the name is changed and it is published, the original continues to work and the new renamed copy does not work. That makes no sense. It does not appear to be the desktop application injecting something that embed API does like as it can modify an older report and re-publish (replace) and that report will continue to work. Only newly named reports do not work as if there is a limit in how many can work (ridiculous) or that the infrastructure has changed in a fashion that when a new space for report is allocated it does not work in the embed API (somewhat logical).
